I'm puzzled about the use of urea (Selective Catalyst Reduction, aka SCR) to reduce NOX emissions. I've read several articles about its use (most recently Diesel Progress May 2008). It seems that it has been well developed in Europe's heavy duty trucks.
Lowering NOX and particulate emissions in diesel engines is difficult. The following is probably over simplified. However, to lower particulate (and increase efficiency), the compression ratio and injection pressures must be increased but at the expense of higher NOX emission. To lower NOX emission, the compression ratio must be lowered but at to expense of greater particulate and lower efficiency.
If SCR is used and it is very effective at reducing NOX, why not go that route. Urea is not a cost driver (availability may be a problem initially). It allows the engine manufacturers to concentrate on better engine efficiency and better mileage.
I understand the EPAs concern about end-users not refilling the tank, but it seems like that could be addressed. If I had to spend $10-20 (I don't know its exact cost) to fill the urea tank every oil change and got 20 mpg on my unloaded truck, I'd do it.
