NOX Sensor
Intermittent coolant leak when towing 2017 HO DRW
P0702 and blown ABS fuse
If there was a recall the dealer would have known about it before they charged you. Post the last 8 of your VIN and we can confirm if the truck was involved.
Apparently that recall only applies to CA trucks - but why would it not apply to all Cummins engines with the same NOX sensor?
My last 8 of the VIN - EG226383
One open recall, R46
R46 FRONT SUSPENSION TRACK BAR FRAME BRACKET See Global October 2, 2015
Complete Recall
Recall Number Description Launch Date Repair Date
P15 REPROGRAM RADIO FREQUENCY HUB MODULE May 3, 2014 July 25, 2014
P26 REPROGRAM ANTI-LOCK BRAKE SYSTEM MODULE November 13, 2014 August 23, 2021
R23 REPROGRAM OCCUPANT RESTRAINT CONTROL MOD August 21, 2015 August 23, 2021
R36 STEERING WHEEL WIRING September 4, 2015 August 31, 2021
T05 SELECTIVE CATALYTIC REDUCTION CATALYST March 30, 2017 August 31, 2021
T25 OCCUPANT RESTRAINT CONTROL MODULE June 22, 2017 August 31, 2021
T51 DIESEL WATER PUMP November 1, 2017 August 31, 2021
T79 BRAKE TRANSMISSION SHIFT INTERLOCK January 4, 2018 August 31, 2021
V44 2013-2018 D TRUCK TAILGATE LATCH May 16, 2019 August 31, 2021
Y26 2012-21 D TRUCK M14 WHEEL STUDS June 8, 2021 June 30, 2022
Dose anyone know if the obd has to be reset after you replace the NOX Sensor. I replaced mine and the Check engine code keeps coming back on. I
was told that I may have to take it to the dealership to have it relearned.
Did you replace with a factory sensor or aftermarket?
Why did you replace the sensor? Just because it was setting a sensor related code, or did you actually diagnose it as being a bad sensor?
I have had the code come and go for at least a year, then just last month it came back an did not go away. I had cleared the code and it came back on two days later.
Thanks to you , it was not the nox sensor ,but CCV filter needing replaced , changed it out ,all has been good for the past year ,and half . thanks again .
