np241 question
Interior Grab Handle?
Clutch problems
I'm rebuilding my transfer case and I'm wondering how to remove the needle bearing (front output shaft) from the rear half of the case.
Thoughts?
When you have bearing in a blind hole, you can fill the bearing full of grease then use a shaft that size and thump it with a hammer. I will create hydraulic pressure and force the bearing out.
Usually yes on this, but I would not on that paper thin aluminium case. there is a fair chance to push out the wall behind instead of the bearing.
An inside puller is the way to go.
Good call.
Thanks for the replies all. I had a coworker suggest using wadded bread - I've seen that work with pilot bearings. I tried it using a large socket with an extension inserted backwards as a driver but it didn't seem to budge, so I'm going to try a puller next.
If that doesn't work then I suppose I'll have to cut the bearing out with a Dremel tool.
