Thought I would share another wheel find that is not posted on the manufactures web site:
Its called "Fuel" is 17x8. 5 it has a 5 3/8" back spacing and a +15mm offset
8 on 6. 5 lug pattern, rated to 3100 lbs. Has a 5. 15 center bore and you could use a hub centric ring but the manufacture says the wheel is lug centric and would center up that way. Using a hub centric ring will not increase the load rating or center the wheel any different according to them.
3 colors are available and look like these but in an 8 lug.
