I believe I found the Answer - Very Very long
Using High Impact Transmissions website:
http://www.high-impact.net/transmission_and_gear/nv4500.htm#What is involved
On 96 and later GM transmissions, both Dodge and GM are the same type shifter and same otherwise except input shaft size and length. Someone please correct me if I am wrong. Wayne
I quote:
"Swapping input shafts: In some conversions, a Dodge input shaft is used in a GM trans, or vice versa. When we supply the trans, it will come with the correct input shaft in it for the application. If you already have the trans, and need to change the input shaft, this is easily done from the front of the unit and Does NOT require major disassembly of the trans. It is recommended to check main shaft end play after the swap, incorrect endplay can cause premature trans failure. To check end play, use a magnetic base dial indicator, zero it in on the rear of the trans main (output) shaft. use a small pry-bar or screwdriver to move the mainshaft in and out of the trans, reading play on the dial indicator. Should be . 002-. 006:...
... Beginning in 95’, all GM units were built with the same gear ratios as the Dodge unit... "
GM 93-94 only First Gear 6. 34
Second Gear 3. 44
Third Gear 1. 71
Fourth Gear 1. 00
Fifth Gear 0. 73
Reverse 6. 34
ALL Otherwise:95/up GM; 93/up Dodge
First Gear 5. 61
Second Gear 3. 04
Third Gear 1. 67
Fourth Gear 1. 00
Fifth Gear 0. 73
Reverse 5. 61
Specifications
Dry weight: 195 lbs.
Oil capacity: 1 gallon
Rated GVW: 14,500 lbs.
Case material: cast iron
Synchronizers: Carbon fiber composite
Main/Counter shaft bearings: Timken tapered roller
Bellhousing Bolt Pattern:
GM 1993-1995 10. 078 across the top, 10. 394 across the bottom, 4. 685 vertically
GM 1996 + up 10. 078 across the top, 9. 738 across the bottom, 6. 043 vertically
Dodge (All) 10. 078 across the top, 9. 738 across the bottom, 6. 043 vertically
Note they are all the same after 96.
Based on this website, the fellow in Nevada was talking BS.
Same transmission, short of Input shaft ater 95.
I was concerned that I just do not have enough transmission.
While, it would be sexy to have a 6 speed in my Chevy truck, with a 5. 9L Cummins, there is little gained to go to a Dodge NV4500. Perhaps I should change my truck to a Dodge flywheel and larger 13". clutch?
I had this conversation with Carolina clutch when I bought my LUK kit. Unless I was pulling sleds and routinely "dumped the clutch" at full throttle, it is doubtfull I could break the input shaft. Ironically, also I was told that unless I upgraded to the 13" plus Dodge Cummins clutch, I had more clutch with the 12" GM flat-face style LUK than with the 12. 5" Dodge variant (even a LUK). These smaller units faced slippage while the smaller GM would hold. Keep your money. I do not know. I have pulled to twice the GVRW and no clutch slippage and I tow alot. At 80K, my LUK clutch look like the replacement other than coloring. Held up good. More than I can say about the NV4500.
At each of my two failures, fluid level is perfect. The first one I lost all but 4th gear. The second, I lost all gears. Just cleaned the teeth off the gears. Failure occurred both times in 5th at 62-64 (1875) on cruise with load on 4:10 gears. Heat? Yes, likely.
I have ordered the NV5600 Fast Coolers from Geno's. Sent back the NV4500 Fast coolers because they will not work on the left side of a Chevy conversion, it hits the drive shaft.
I sorta got told some BS by an eggsspert in Nevada.
Have I sufficiently stirred the pot?
Wayne
