98 model 12 valve. NV4500, about 25k on new bearings, syncros and mainshaft. Stuck in 4th gear three times so I pull it to find the flat back on the thrust bearing in a dozen pieces. Apparently these little pieces can get cocked sideways in there and prevent the shifter cog from sliding back into neutral after it's in gear. Any idea what would cause the bearing to go? Did I get the endplay too tight when I assembled it the last time? Have you seen anything like this? Any ideas appreciated.
-Scott
-Scott
