Hi guys, I need your advice on the NV please. I run a 1st gen. D-350. This is used as a Hotshot. I pull 36,000 lb GVW on a daily basis. The truck is getting a Reman Cummins 215 hp motor installed as we speak. <Orig. 160 hp> I'm on my 2nd Getrag 5 speed. Any other "heavy" load pullers on here using the NV? How does it work for you, and is it holding up well? Do not care about the price or needed changes to the truck to be installed. Just interested in the performance of this transmission. I'd appreciate any honest thoughts. TIA, Mike
92 Std cab. LE. 210,000, 5-speed, 3. 54, 105 gal Aux tank in bed. Banks Power pack. 14cm 4" exh. w/wastegate. Pyro & boost guage, oil temp guage. Rebuilt pump turned up, fresh injectors. E-brake. Used as a Hotshot/express Reg. at 36,000 lbs in 48 states. http://hometown. aol.com/hotshothauler/myhomepage/business.html
