Engine/Transmission (1998.5 - 2002) NV 5600 oil capacity
The 5600 capacity is 9. 5 pints assuming no fastcoolers etc. Change on level surface and fill till it comes out the fill plug hole works as good as anything.
To overfill it a bit, run both left wheels up on tire ramps . this lets you put in like almost 2 quarts over. .
I have the new Trans coolers and I have like 6 or 7 quarts so when it is tilted like that, I fill til it runs out... This seems to do pretty good for towing.
I would put in 8 qts through the shift tower. The rear main bearing needs all the help getting lube that you can give it. I started out with 11 qts but it was too much, 8 should be fine.
Godspeed,
Trent
Thanx to a dealer service in Sioux Fall... I found out the hard way that you can run one for quite awhile on 4 qts with Fast Coolers... . But once you get up to about 85 the trans will lock solid. So much for trained techs knowing how to check dipsticks.
Welp you got me, I didnt pay attention to your whole post with fast coolers so thats my fault. Ill def pay better attention next time!
