NV 5600 oil leak
04.5 Engine Noise Increasing
Local Oil Analysis "Mass"
Bug Out
I just discovered a oil leak which looks like its coming from the top of the trans. and seeping down to the bottom via the sides.
What could cause this? Was finally going to put on oil coolers, but will wait now.
Looks lie off to the dealer for first warranty work.....
Thanks, Ed
shifter loost on the trans... oil can leak if that happens... there's 4 bolts mounting the shifter to the trans [i believe they are 8mm... ?] if one or more is loose, the rubber isolator could be seeping oil, or the silicone that seals the steel side of the isolator to the trans isn't doing its job and is leaking there.
