I noticed a couple days ago a very slight noise ( my wife could'nt hear it at first) like something rubbing when I release the clutch in neutral at idle. Goes away when you push the clutch in. Clutch does not slip and there is no other symptoms, or noises. I'm guessing throw out bearing.?, Or could it be the hyd system for the clutch not relasing the bearing all the way? Like I said ther is no other symptoms, and you have to listen close to hear it, maybe im being paranoid. Any advice would be appreciated.
Truck has 115,000 miles.
