NV271 case bolt torque #'s???
EJA Durability
change in oil color
I pulled my t-case apart to check a few things and I can't find the torque speces for reassembly. I have tried Google and the search feature for the last hour and I am getting no where fast. Does any one have a link with the t-case torque specs?
I need:
front output nut
front to back case bolts
tail housing bolts
TIA,
Aaron
"The Premiere website for Hemi Ram and Hemi SUVs. "
I know it says Hemi, but they have a link to the 03 service manual. Look on the left side of their home page, and scroll down to just below the picture of the gal with the short shorts. It is a .pdf file, so may take a bit to load. I know there is a chapter in there about disassembly and reassembly of the NV271. Should be some info about torque in there.
Good luck..... Steve
TRANSFER CASE - NV271
TORQUE SPECIFICATIONS DESCRIPTION N-m Ft. Lbs. In. Lbs.
Plug, Detent 16-25 12-18 -
Plug, Drain/Fill 20-34 15-25 -
Bolt, Extension Housing 27-34 20-25 -
Bolt, Case Half 27-34 20-25 -
Nut, Range Lever 27-34 20-25 -
Sector Support 27-34 20-25 -
Nuts, Mounting 30-41 20-30 -
Position Sensor 20-34 15-25 -
Nut, Companion Flange 176-271 130-200 -
