Well, I'm not having a lot of luck selling this nearly new Enterprise Engine Mitchell Dual Disc clutch that was new with the truck I just bought. As luck would have it though, today as I was calling around trying to get people to put an ad up in their shop for the clutch, I ran across a guy who has the same clutch with the 1-3/8" shaft. The clutch itself is shot, BUT the shaft and hubs are in good shape. My question is this. What all do I need in the 1-3/8" size in order to run the larger shaft?
I know I need the following:
1. Hubs from the two friction plates
2. the entire disc that goes between the friction plates
3. The input shaft itself
What else?
1. Will the flywheel I have already work with the larger input shaft? Just a bigger pilor bearing maybe?
2. throwout bearing have to be bigger?
3. Pressure plate?
4. Are their other WEAR parts that I will have to replace? I can use my existing brand new friction plates and just have the bigger hubs mounted in them.
I don't know what all has a center that must mate up to the bigger shaft.
Thanks for the info.
What else?
3. Pressure plate?
