running gear is all fine. You need a different engine adapter,bell housing and longer line to the slave cylinder. You also need to make a bigger hole it the tunnel for the shifter and get a second gen starter. Also leave the seal out of the back of the trans and silicone the bolt flange well. And use a piece of tubbing to adapt the cross member to trans. I think thats about it, hope i didnt miss anything.
