I have expressed different levels of strife on the TDR about what I have had to go through to get this conversion done, and now it is after two months of weekend/evening work. I will first say that Standard Transmission and South Bend Clutch really try to take care of their customers and their help was a great resource when problems occured along the way. Second, the conversion was worth the money, my truck does feel totally different, tons smoother, quite, and now it shifts like a race car. The south bend clutch, although I had a hydraulic problem that felt like a clutch problem, is so nice, smooth, no jerking, and feels confident.
Now, here is my one plea, if you do this conversion, please consider using another source for your bellhousing and related parts. I went the advanced adaptors route, and was floored with the lack of instructions, no list of parts that are not supplied, but are necessary to complete the conversion, and low quality of the parts they sent.
Bellhousing:
1. You must "clearance the ears" where the mounting bolts thread into it to provide enough clearance for the flywheel. Not too big of deal, but come on, how long have we been casting things here in this country? And besides, advanced adaptors claims to have the highest technology in machine tools at their shop
2. I don't know what the deal was with this, but it really made me hot
The hole in the bellhousing where the bearing retainer goes through was to tight of a tolerance only . 002" where the getrag has . 0025" (is that right?) So to get it to spec, I had to take my "new" bellhousing to a good machine shop and have them bore it the rest of the way for another $75, and of course wait for it.
Shift linkage for t-case:
1. They gladly send you the bracket that most trucks don't use, and give no real ideas as to how to figure out which you will need. Also, it will be nearly impossiable to install this bracket with the transmission in the truck, so please wait and spend another $77
2. Get this bracket and install it. Whoops, the yo-yo's powder coated it so it wouldn't rust, but threaded the holes beforehand, so spend more time and vulgar language on taping them out. Holes also did not line up just right on transmission, another delay tuning them.
3. No instructions as to how long to make the new shift rod, and, and ... ... ..... and no way to adjust it when it is up in place :-{} So, fiddle with this, measure my other truck, and wonder what part of this conversion does not require engineering.
Transmission mount adaptor: Flimsy, enough said.
Finally, thank you very much to our own Bob Beauchine, and Peter at South Bend Clutch who helped me figure out why after all of this work, my clutch would not disengage. Yes, Peter I didn't believe it, and Bob you were right, replaced the entire hydraulic system, clutch works like a charm
Thanks to all for their support, and I hope that the info above can help you make a better desision then I did!
Russell
Bellhousing:
Russell
