I am having a problem with the clutch in my 5 speed transmission. If I am stopped with the transmission in gear and the clutch pedal on the floor, the clutch slowly starts to engage. It will get to the point where I am either forced to start moving because the clutch has engaged enough to start moving the truck, or I have to shut the truck off to get it out of gear. I usually leave the transmission in neutral and the clutch pedal up when I am stopped for a longer period of time, but in shorter stopped times I usually stay in gear with the clutch pushed down, but this obviously isn't working now. Hopefully this isn't difficult or expensive to fix. Any ideas on what might be causing this and how to fix it?
Thanks,
Lance
Thanks,
Lance
