NV4500 Conversion
GMC Cummins/4x4 Conversion (pictures!!!)
4BT Vibration
I recently did the NV 4500 coversion on my 1993 D350 CC LB .
I did the clutch flywheel,new drive lines , joints the works , rear end !!!
was up on the rack for new shocks ... and found gear oil leaking form bellhouseing an rear seal!!!! is this a common problem with these trannies????
this is all brand new parts no used ones!!!! have just under 2300 miles on it !!!!
did you buy a used bellhousing? the chance you take is getting one that is warped. unfortunately you are gonna have to pull it all apart, it is definitely NOT supposed to leak!!
dawna
