On the side of the NV 4500 transmission below the fill plug is a cast boss that obviously was intended to be a drain plug, Has anyone drilled and tapped the boss for a pipe plug? Cast iron usually taps easy but a few years ago I created a huge problem for myself on an expensive piece that was to hard to tap with normal tools so I'm a little gun shy on some stuff now. Has anyone tried this or had problems? Is the case just normal soft cast iron? Thanks
Jared
Jared
