NV4500/hydraulic clutch question
Long burnouts
What color on clearance light housing?
My NV4500 takes some time downshifting into third or shifting into gear while stopped. Sometimes it takes a second tap before the syncros cooperate. It is a little notchy going into the other gears as well. I've driven it for a year like this never really knowing if that is how a NV4500 is suppose to act or if I got swindled on the transmission I bought.
Could these be sympotoms of a clutch that is not fully disengaging?
When I did the conversion, I used a '95 bellhousing and clutch fork and retained my '92 clutch and slave cylinder. When I put it all together, it seemed to fit and work, but now I have some doubt.
when you did your conversion did you use a kit ?
from what i have gathered if you used a kit you
can retain your stock hydraluics if you did not
and used a stock nv4500 bell houseing you need
to up grade the slave and master cylinder.
it is also my understanding the runout of the
engine to transmission adapter can cause a load
in the input shaft causing clutch and transmission problems
i think the max it can be is . 008 out (this is the adapter centering
around the crank shaft)
I did not use an aftermarket bellhousing kit. The Getrag and NV4500 slave cylinders have a different part numbers, but they look identical from the outside, so I saved some money by using my old slave cylinder.
Do you suppose the slave cylinders have a different internal bore diameter? I'd like to know the bore diameters for both slave and mastercylinders.
