Nv4500 Into Automatic Truck
Getrag 360
2nd diesel
O. K. HERE IS WHAT I'M THINKING... MY JEEP HAS A NV4500 WHICH WOULD BE MUCH HAPPIER IN MY TRUCK... AND THE JEEP COULD BENEFIT FROM THE AUTO FOR ROCK CRAWLING. ANY WAY... IF I CAN FIND A FIRST GEN 5-SPEED WIRING HARNESS AND COMPUTER, I COULD SEND MY COMPUTER WITH THE TRANS INTO THE JEEP.
ALSO, HAS ANYONE CHANGED AN AUTO TO A 5-SPEED?
I GUESS I'D NEED THE PEDAL SETUP AND MASTER CYL.
IF ANYONE HAS A FIRST GEN 5-SPEED TO BE A DONOR LET ME KNOW. ANY IDEAS APPRECIATED.
SEANE
Seane, I would hazard to guess the 4500 in your jeep is for a gas pot and may not be suitable for use in your powerfull diesel. jm2cw. bill
THE JEEP HAS A 4BT DIESEL, WITH A HDNV4500... EVERY THING SHOULD BOLT RIGHT UP FROM ONE VEHICLE TO THE OTHER. THE JEEP HAS ALL DIESEL DODGE TRUCK PARTS.
THANKS FOR THE INFO ON THE LINK... I'LL CHECK IT OUT.
aah:D clear as mud now should work fine and if jeep has hydraulic clutch you may even be able to use the set up for you dodge. bill
I have a 97 model NV4500 4X4 trans that belongs to a friend. It has 70k miles on it. I do not know if it has had the 5th gear nut fix done. I bought it out of a wrecked truck 3 years ago.
He told me tonight to sell it. Hit me with a pm if your interested. We can work something out
SClements
From your post count it looks like you're a recent member of this forum, if I may suggest, not to use all Caps. That is hard to read and also considered to be shouting.
Thanks!
PS Welcome to the forum
