nv4500 new in 93 makes grawl when on it why
Not shifting into OD correctly.
Straight pipe straight dope?
my 93 has a nv 4500 new , when i go over about 10 lbs boost in 5 th a get a gwawl
or vibartion
mainly does it in 2nd going up steep hills
w/ any thing greater then light boost.
new center draveshaft support,
can make it do it in any gear, w/ over 10 lbs boost
could it be u joints?
1993 w350 ex cab, banks,nv 4500 in
open exaust, pw Injectors are in. Big rig flaps,tach in,. Its loud and goes ok, for a 93,Ham radio Call KK6dm
has ability to communicate any where in the world. Headliner shelf
5 antenna's
Mine growls in fifth gear also; but I do not have any vibration associated with it however.
'93 D250 CC 210hp nv4500 5spd straight exhaust grover air horm
My '93 2 by will "rattle" in 4th and 5th from about 1700 to 1800 rpm and is more pronounced when I'm towing. I've got no unusual vibration - I have had the driveline rebuilt including the center carrier bearing. The slip yoke was also replaced. Hope this helps.
Happy Trails
1993 250 4X2 - Banks Power Pack, BD Power Injectors, K&N Air Filter, 6 gauges and tweaked pump. 27lbs boost unloaded.
Horton fan & NV4500 5 speed.
Mine does the same thing in 4th and 5th,mainly in 4th at low rpm when I mash on it. The bearings are making the growling noise,or so I was told. Your better off stepping on the go pedal at a higher RPM.
88 GMC CREW CAB 4X4 89 6BT,NO INTERCOOLER YET,AUTO METER LIQUID FILLED GAUGES,NV4500,NP205,4. 10's,35 BFGA/TKO,6" LIFT,DETROIT LOCKER,16CM,K&N,3. 5 EXHAUST,BD "PRINCE OF DARKNESS"INJECTORS 96 215 hp on the way. J. Mason
My Getrag does the same thing when I am pulling hard towing my boat if 5 gear. I have the Banks package. I think that it is the hormonics that are set up under this condition. My truck only has 84000 miles on it. It may even be that Banks Muffler. Mark
1990 4x4 one ton single rear wheel, banks package, intercooled.
I heard that if you replace the u-joints with spicer u-joints that noise goes away.
  • '93 250 LE 4x4 5spd 4:10 Loaded,dual 5" chrome stacks,12cm² turbo(37psi),PW injectors,K&N,pyro/boost,US Gear E-Brake,tool box,CB,10" AR rims, 285/75/16 Bf goodrich. "wirenut_21529" on Yahoo Messenger
  • '97 Ford B-Series school bus (5. 9 Cummins!)I'm gonna Bomb it!
  • '94 GMC 2500 6. 5L Turbo
PICTURES.
Have you checked your exhaust system ? At the transmission cross member the exhaust doesn't have much room. IF the exhaust pipe is touching or almost touching the frame it will make noise & vibration like you are talking about. When the pipe makes contact with the truck it amplify the noise big time. If the pipe is close, but not touching it might be making contact when you put a load on i. e. 4th or 5th gear. Hope this helps, hate to see a new NV4500 with problems.
Kyle
1985 DODGE 1 ton Crew Cab(imported from California with no rust) W/8' box converted to 4X4 in 1999. Converted to a non-intercooled 1991 Cummins Turbo diesel & rebuilt 5 speed Getrag in 2001(wife can't drive a stick :). Freshly rebuilt and Balanced Cummins, Rebuilt NP205, Rebuilt Injector pump and tweaked, Matched Injectors, 3" New Mandrel Bent Exhaust,no muffler, Borgeson Steering Shaft, K&N Air Filter, 4:10 gears, limited slip rear end, 16" Goodyear GSA Wranglers, 16K Reese 5th Wheel Hitch,and LE Package and a Sony CD Stereo. Next add-on some “Banks” toys ! If you want to know why I did all of this, 2 kids, one on the way and I can't stand F**d and Ch**y. Kyle Hoover ,Fruitport, MI.
well it too does it in any gear
over about 10lbs boost did not do new
has only 8 k miles on it
not so much vibration , but a grawl
when i step on it to pull hills on fwy
it does it if i back off to less then 10
lbs then no noise, it must be a u joint?
bill cant look until saturday
5 antenna's
