I've got 103K on my '98 and it's to the point that it is very difficult to get into gear from a stop. Fluid has been changed twice at 35K and 70K. Fluid looked good both times but at 70K it was starting to shift hard and I noticed very little or no improvement with the change. Both times it was filled with the GM equivalent oil. Oil appears to be pretty contaminated now. So now I expect it's time for a rebuild. I'm tempted to take it to Quad 4x4 to avoid me having to drop it and put it back in. (About 300 miles) I should probably bite the bullet and do it myself though. I'm confident that I can do the rebuild myself. 5th gear has never been a problem. I tow very little but when I do it is usually heavy. (up to 30K) So. Would you do the fully splined mainshaft, and who's? Reading on Quad's site it sounds like theirs is the best and for good reasons, but overkill for me? What overhaul kit from Quad? I would probably put their ball bearing pilot bearing in also. I'll also do a clutch at that time. Probably go with something from SB. I need to call Quad and discuss this with them. Anybody have any words of wisdom?
Kim
Kim
