Hi all,
Well, I ordered the new 5th nut and the tools to fix my (supposed) 5th gear problem. I was getting a whining noise that has been increasing over the last 10k miles. I put the truck in my garage, drained the trans fluid (I'd just changed that 6k miles ago) and saw lots of gold and silver specs all through the oil:
uh-oh. Separated the transfer and tail housing from the trans and looked at the nut. The nut and gear both looked/felt tight. I turned the output shaft by hand and it was smooth for half a rotation and then felt "notchy" for half. I got a flashlight and looked into the trans... lots of metal particles there---a whole layer of metallic sludge in the bottom of the case. Looked some more and recovered half a bolt! About a minute later I discovered where it had come from. It was one of the four bolts that hold the output bearing retainer plate onto the back of the trans. The other half is still in the trans, broken off pretty much flush with the case. I'm thinking it was either a bad bolt or the person who did the assembly over-torqued it and twisted it pretty much to failure before having another sip of coffee and sending it down the line. I can see where the bolt has been ground around in the case chunking some aluminum off of the tail housing as it went. Probably some gear damage in there too. And of course all the bearings/synchros have been running in metal particles for at least 10k.
I went to the dealer this morning and took the bolt head in. I thought maybe they'd be interested in helping me out, as I only have 44k on the truck. Uh, no. They said they have to cotact the DM (?) and get back to me...
So, looks like I'm replacing the NV4500 in my '99, 44k mile truck that's about half paid for... thanks New Venture.
Does anyone have a contact at New Venture Gear? I'd like to email the pics and at least let someone there know that this happened...
I'll be putting a call into Blumenthal and Standard to see what my options are in a bit.
As always, thanks for any comments/advice/consoling sob stories you can offer.
Mike
Mike
