have a question on my shift top my transmission will not stay in 5th 0r 4th gear when i let off the throttle the synchro sleaves for both gears require a pry bar to move either into gear or out of gear they arent un reasonably hard to move the detent seems to be locking the sleeves perfectly , i have replaced the detent springs and struts in both 5th gear and 4th gear and i have also replaced the springs on the shift rails but the transmission still will not stay in either gear . i just recently rebuilt the transmission and set shaft end play for the counter shaft at . 004 and the main shatft at . 006 what else can i check
