Hi, all.
Past few months, it's seemed harder and harder to get my transmission into gear. Say I'm sitting at a stoplight with it in neutral, push in the clutch and go to grab first (or second, or third... ), and it doesn't want to shift into gear. At first, it just seemed a little slower, but it's gotten to the point that it sometimes doesn't want to go into gear unless I really force it. Generally, if I wait a few seconds and try again, then it will go into gear.
I'm trying to figure out what the problem is--any ideas? I changed the fluid (with Syntorq), but it didn't help. The clutch pedal doesn't feel any different than it used to, and it seems to shift fine at speed--it just doesn't want to go into gear when it's been sitting in neutral with the clutch out. I was worried it might be the synchros, but I'd think that this would only affect one or two gears, and not all of them--unless all the synchros in my transmission went bad at once. Makes me think maybe the clutch isn't disengaging all the way, and the input shaft is still spinning. What do y'all think?
I'd rather get stuck replacing the clutch than having a transmission rebuild--give me an excuse to put a Con O in there, at any rate. :-laf
Also, can anyone recommend a good transmission shop in Central Florida? I'm in the Tampa Bay area, but I'd gladly drive a ways to find a good shop--particularly if anyone knows a place that's done a few South Bend installs (their website doesn't list anyone in Florida)...
