kscheffler
My 2001 with NV5600 and OEM clutch is acting up. When backing up it I have to use the clutch multiple times in less than a minute I start to loose "throw distance" on the clutch. I only have a couple inches of disengagement distance with the clutch being depressed. I also noticed that the clutch will "let loose" and the tires will spin on gravel surface. It only does this if I push in the clutch multiple times in one backing event. Not sure it might do the the same when moving forward but I only noticed it when backing up. What do you think this is the master cylinder is going bad or is this a symptom of the clutch plate slipping? Thanks guys in advance.
