Had a BIG incident recently with our 6 spd. The transmission locked up at 65 mph on a cold day with a lite load on the vehicle. Initial indication was rear wheel lockup!!! This in turn sheared the lining from the clutch causing a DOA. (towed in by an S-10) I pulled the transmission and found it locked in 1st gear with the shifter in neutral. Put the shifter in any gear and input and output shafts are locked tite. Disassembly at the transmission shop showed 1st gear welded to the main shaft. The truck has 70,050 miles and the transmission was full with mopar spec fluid at the time of failure. I had changed the fluid @ 35,900 at the dealers recommendation. I am no longer confident in the reliability of my rig, which of course is a major issue. Any help?
