I have read a bunch of different posts but couldn’t find a concrete answer for a fix to issues I know others have had or are having.
I purchased a 04 Cummins NV5600 w/176,000. It has a South bend duel clutch and upgraded Hydraulics. As soon as I got it I changed the trans oil and put in 8 qts of amsoil.
I’ll try to be as detailed as possible describing the problems I’m having.
SHIFTING INTO 2nd FROM NEUTRAL
- Once the truck is started I usually cannot shift from neutral into 2nd without putting the stick in a random gear first and even after shifting into another gear its definite not smooth going into 2nd.
- If I come to a stoplight and put it in neutral I have the same problem as above.
SHIFTING FROM 2nd TO 3rd
- in order to not grind gears when shift to 3rd from 2nd I have to slowly accelerate and let the rpms climb to about 1800rpm, then slowly shift and let it fall into to gear. Basically synchro matching. Even if i moderately accelerate it likes to grind and if I let the rpms climb above 2000rpm it likes to grind.
SHIFTING FROM 3rd to 4th
- from 3rd to 4th it basically have to shift it the same was as I do when shifting from 2nd to 3rd although it’s not as bad.
SHIFTING FROM 4th to 5th
- not problem
-SHIFTING FROM 5th to 6th
- there is no problem here but I can’t use 6th if I’m going slower then about 65. If I shift into 6th at say 50 the truck feels like it’s surging
Any ideas what the issue might be? Is my clutch not disengaging, is the pilot bearing bad, is the throwing Bearing bad. This is my first 3rd Gen and don’t know if it’s just something I have to deal with or not.
- not problem
