I purchased a take-out NV5600 transmission from a 1999 4x4. When the Getrag 360 let go, I started working on the conversion. The 1. 25" x 10-spline input shaft is longer than the Getrag by about one inch. When I tried to pull the transmission up to the block, it bottomed out with a one inch gap remaining.
I think the flywheel for the 1999 must be different, because this transmission came out of a '99. Can anyone confirm this? Will the '99 flywheel bolt up to my crankshaft? Any differences in engine balancing?
I have to get past this problem before I even consider, transfer case shifter, crossmember, driveshaft mods. Heck, I can't even see the light at the end of the tunnel. Any help would be appreciated. Thanks. Gil
