Engine/Transmission (1998.5 - 2002) NV5600 mount replacement
going to replace my transmission mount. do I have to do anything special. do I have to drop the driveline? is there enough room/play to unbolt old one and jack up enough to slip out? thanks for the help
2002 HO 6-SPD LB 4X4 QC HTT 62/14 SB-FE TST PM3/*REVO-BETA*SMARTY MACH 4'S, RINGED AND STUDS, AFE/2:eek: " FTE 6" STACK D/PRICOL GAUGES, FASS 150, VULCAN 1/2 DRAW-STRAW, 3/8 FUEL LINE, DSS-TRAC-BAR STEER-BOX, AIR BAGS,17'' KMC BLACK HOSS, 315/70/17 MICKTHOM MTZ'S 6" RCD LONG ARM LIFT. :-laf... THANKS RIP Source Automotive Performance Diesel - Offline
That's what I did when I changed my clutch. I just jacked it enough for support and put my stands under it and left it there while I worked.
It was way more room needed to change out a mount.
