History: loud on/off/on/off squealing from transmission on the freeway, all gears OK, dealer can't diagnose. I couldn't repeat it either, even after 80 miles of freeway driving.
This weekend I drained some fluid out and found it slightly burnt (50k miles), but at the proper level and with just a little bit of debris. Debris consisted of mostly black RTV chucks, 1 piece of grey metal the size of a half a rice grain, and a few tiny specks of yellow metal. Proceeded to completely drain the fluid and didn't find much more metal, but I did find a bunch of RTV silicone. I cleaned the magnet in the bottom of the transmission and the magnet on my Fast Cooler and only found the typical sludge, nothing major or excessive. Sealed it up, put in 3 qts of fluid before I found the seal was not sealed, redrained to fix seal and got even more RTV out, some chunks as big as a pencil eraser. Filled with 10 qts (3qts overfilled with 2 qts in the Fast Coolers) of Redline MTF and drove it to work today... happy to see cooler temps, smooth shifting, and possible quieter operating. I would really like to drain the fluid, filter it, and put it back in after a few hundred miles to get all the silicone out... at the same time use gaskets instead of RTV on the PTO covers.
Question1: RTV floating around can't be great, but is it a bad thing, and could it jam a bearing bad enough to make it squeal? Any other bad effects?
Question2: Dodge doesn't sell gaskets for the PTO covers, does anyone?
