Engine/Transmission (1998.5 - 2002) nv5600 shift lever question
2nd Gen Non-Engine/Transmission Don Thuren vs. Solid Steel
Engine/Transmission (1994 - 1998) Compound / Twin Turbo Suggestions?
question on nv5600 while in gear the ammount of play the shifter has. has never popped out of gear shifts fine just seems to have 3/4+ movement. is this normal with miles. I have never took apart the top have on the shifter so is there a bushing that is wore down. is this a no big deal thing or is this a early bad sign.
2002 HO 6-SPD LB 4X4 QC HTT 62/14 SB-FE TST PM3/*REVO-BETA*SMARTY MACH 4'S, RINGED AND STUDS, AFE/2:eek: " FTE 6" STACK D/PRICOL GAUGES, FASS 150, VULCAN 1/2 DRAW-STRAW, 3/8 FUEL LINE, DSS-TRAC-BAR STEER-BOX, AIR BAGS,17'' KMC BLACK HOSS, 315/70/17 MICKTHOM MTZ'S 6" RCD LONG ARM LIFT. :-laf... THANKS RIP Source Automotive Performance Diesel - Home
I have about 1/2" side to side when in gear, is that what you mean? It never gave me a problem, except I tend to push it to to far over and can't hit reverse until I bring it back some, maybe 1/4" inch. That is my only problem/complaint with my 5 speed. I was going to put a short throw, but I heard there could be problems with them so I an sticking with a stock shifter.
DW,
Mine has about 3/4" guessestimated front to back movement at the knob. Trans has about 68K on it, stock shifter.
NV4500's have had two different shift tower types, my '97 shifts like a old truck, long loose throws, NV5600 much tighter.
I have a BD short shifter & it's wonderful for me. Not much slop at the shift knob.
so I take it this is normal over time but is this a bushing issue I have never looked at the shift lever and how its put together. wondering if there is a bushing in there somewhere or at the end that would tighten this up. I know when I first bought the truck it was tighter. but I have over 150k on the truck now.
