I've had my truck now for about a month, and I'm curious as to how "out of whack" my shifter really is.
The way you have to position the stick in this truck is unlike anything else I've ever seen. It's almost as if there's some internal plate in the trans thats shifted, and won't allow me to pull it into gears normally. In fact, most people that drive my truck, can't get it into any gear without me telling them the right movement.
For example, here's what you have to do to get it into gear(all movements from N):
1st: Straight left and up (no probs here)
2nd: Straight left, and down at a "4:00" angle.
3rd: Straight up at "11:00" position"
4th Straight down from 3rd
5th: Worst gear to grab from neutral, almost straight right , and then back to about 10:00.
6th: straight down from 5th at almost 4:00 position
R: Most messed up gear I think-have to go straight right then up at least 2 or 3 times for it even to engage. Once it engages, it usually grinds.
I am also getting a nasty 5th to 6th gear grind whenever I shift fairly quickly.
Hopefully someone has experienced this, and can lend a hand. I tried searching, but I don't even know what to search for at this point.
Thanks in advance, for all the help.
