Hi all, normally I am over in the conversion board but I know alot of this one have done the NV4500 to NV5600 swap. What I am wondering is if anyone has measurements on the size of the NV5600 and also the T-case for behind it. Reason being is that I am just starting to work on my 89 GMC that I am swapping in a NV5600 cummins into. Reason I need the dimmensions is because I decided to put a pair of 2003 GMC heated leather buckets into the truck and I had to totally modify the floor and on the passenger side I even had to cut into the tunnel. If anyone has the width and height of the transmission that would be great and also does anyone know if the T-Case sticks out past the transmission on the passenger side? I know the drop down and output is on the drivers side but I need to know if there will be enough if any clearance on the passenger side. Anyone with pic's or measurements would be great.
Thanks... Ryan
Thanks... Ryan
