Engine/Transmission (1998.5 - 2002) NV5600 Size???
2nd Gen Non-Engine/Transmission Hey Toolman/Mini-Me ?
Engine/Transmission (1998.5 - 2002) BOMB's are in...
Hi all, normally I am over in the conversion board but I know alot of this one have done the NV4500 to NV5600 swap. What I am wondering is if anyone has measurements on the size of the NV5600 and also the T-case for behind it. Reason being is that I am just starting to work on my 89 GMC that I am swapping in a NV5600 cummins into. Reason I need the dimmensions is because I decided to put a pair of 2003 GMC heated leather buckets into the truck and I had to totally modify the floor and on the passenger side I even had to cut into the tunnel. If anyone has the width and height of the transmission that would be great and also does anyone know if the T-Case sticks out past the transmission on the passenger side? I know the drop down and output is on the drivers side but I need to know if there will be enough if any clearance on the passenger side. Anyone with pic's or measurements would be great.
Thanks... Ryan
Might not help much since the widest part of the transmission is probably below the floorpan, but I measure about 12 inches wide at the bell housing and at the transfer case adapter. The adapter itself is 8 inches wide where it mounts to the transfer case and the transfer case may be 1 inch wider than that on the passenger side, but definitely not as wide as the transmission.
