nv5600
need 600 hp on #2 only
Plastic intercooler on 05?
I have a nv5600 sitting here and it has some type of electrical connection near the back of the transmission. What is this for?? Speed sensor??
fkovalski said:
Did the computer dash "light out" indicator pick up the problem?
i don't believe the lamp out circuit moniters the reverse lights as i have no reverse light bulbs connected to the factory wiring and i get no lamp out light on the dash [i have one coil side of a relay in the factory circuit, but i installed that after trying to see if the lamp out detected the removed reverse light bulbs]
edited for my brain fart on not proof reading what i wrote
nickleinonen said:
i don't believe the lamp out circuit moniters the reverse lights as i have no reverse light bulbs connected to the factory wiring and i get lamp out light on the dash
Doesn't that mean the lamp out circuit does monitor the reverse lights? I think I'm confused... :confused:
-Ryan
-Ryan
i removed the back up lamps to check, the lamp out light never triggered :)
nickleinonen said:
i don't believe the lamp out circuit moniters the reverse lights as i have no reverse light bulbs connected to the factory wiring and i get lamp out light on the dash [i have one coil side of a relay in the factory circuit, but i installed that after trying to see if the lamp out detected the removed reverse light bulbs]
i had the lamp out light coming and going with all the lights working, replaced the tail and stop lamps and the contacts on the bulbs were worn, enough to cause the lamp out to illuminate, also try to tighten the contacts to make the bulb fit tighter ;)
-Ryan
i really should proof read more carefully:eek::eek:... . it should read
