Engine/Transmission (1998.5 - 2002) Nv5600
2nd Gen Non-Engine/Transmission where to get a new track bar?
2nd Gen Non-Engine/Transmission Help-loud clunk/bang in 4WD only
I believe there is a simple little valve on the top that will open and force out any extra as it gets to moving about the transmission. I have mine torn to pieces but I'll look a little later. I do know for sure that it IS vented though. I put in 12 qts this summer and made a giant mess all over the underside of truck and the trailer I was pulling!
I have the Fast Coolers and 8qts in mine and it has not vented a drop.
Just wanted to let you all know that this combination works. I am using the Redline MTL and love the way it shifts so far. I only have about 3K on this drain and refill so I will see how it performs after some 10's of thousands of miles.
The vent is located on the top of ther transmission case I access mine from the right or passenger side you can see it and reach up and lift the vent cap which should lift up a quater inch or so it is pressure actuated and lifts/opens if pressure in transmission exceeds weight of cap. When pressure is released gravity closes valve.
what he said
I never did locate the vent. It wasn't visible through the shifter hole in the floor, but I did find the source of my leak. All 4 bolts on the tower were very loose! :eek:
