The 5sp in my 96 TD dropped the 5th gear nut for the second time at just under 150K. Upon repair the 5th gear itself is noq loose on the mainshaft (splines worn). I have been hearing more noise in 3nd and 5th and expect some wear but not failure at this mileage.
From what I have read and heard, replace with new is better then rebuild. I am looking for opinions! I have also heard replace with a 98 - 99 model trans (mopar # 52108131) instead of the 96 - 97 mopar # 52108197). Will the newer fit? The newer is on nationwide backorder so it is going to be hard to get (Must be in high demand!). SCOTT1 ... May need you to check in Canada for availablity.
Would really be nice to have the truck done before the end of the year.
I still have the original clutch and plan on replacing it to. Were is a good price on the Centerforce Dual Friction?
Will give more details on why and how later. The majority of my miles are in 5th gear and it has been pulled hard.
I did expect longer life than this. I tried to get the dealership to push under warrenty or at least split the cost as related to the nut comming off twice but no go. Quote for the regional DC service writer is "It is time for you to pay for your problems... " Called the 1800 Customer # and was told the regional service writers option is final. The first time the nut came off was 4 days before the 97 TDR nationals. My dealership patched it up so I could go. Had a long discussion with Mark Corich (DC Dodge Truck Customer Advocate Group) and expressed my only concern was the Dodge help me with this 5th gear nut issue if it returns. I again talked with him at Columbus. Because the problem rarely shows up under the original 36K warrenty you/I have little to stand on down the road when the problem returns and returns and eventually destroys the the spines on the main shaft like in my case.
Really gives one a bad taste when you have gone out of your way to promote Dodge Diesels.
Jerry Weigel
Bismarck ND
Jerry Weigel
Bismarck ND
