Has anyone heard if the factory fill in the NVG4500 5sp has been changed to the SAME 30wt oil as comes in the NVG5600 6sp?
OR. .
Has anyone had their 5sp oil tested? What was the weight (Visc 100).
On my 96, I replaced the 5sp with a 98 and newer trans (factory new) when I had damage to the mainshaft (prior to Standard Trans fix). I Have 26k on this new trans and sent sample in to see how its doing. Trans oil came back as being 30wt but it is tramsmission oil not engine oil. It also was doing OK as far as wear.
I have lots of samples from my old trans to compare against. Both Factory and Amsoil.
This trans has never shifted as good as the original. I monitor trans oil temps and this one runs 15 - 20 degrees warmer then original. When I grabbed the sample it seemed very thin for "75w85"! Starting to make sence. The transmission are shipped with oil as I understand.
jjw
ND
[This message has been edited by JJW_ND (edited 02-02-2001). ]
OR. .
jjw
ND
