O ringing an 3rd gen?
Boost Gauge-----Is this normal?
tst pmcr dyno run
For those that are O ringed on a 3rd gen truck.
What headgasket did you use when you re-assembled the engine?
The stock headgasket will not work with conventional O rings or Fire rings.
The 3rd gen headgasket is "different" from the rest.
Also these new gaskets shouldnt blow, you should just see leaking from lifting the head.
Someone educate me!
--Justin:D
Nothing is wrong with the cast-iron heads, its because of running so much boost. A stock head gasket was not ment to handle over 50lbs of boost.
John
