Obd codes p004db
Are MOPAR oil filters necessary? Local stock are by Wicks!
No cabin heat and coolant temperature that creeps too high
  • The Powertrain Control Module (PCM) compares the Crankcase Pressure Sensor Signal to the Mass Air Flow and Charge Air Cooler (Out) signals. The PCM sets this DTC if the rationality is above a calibrated threshold for 2.0 seconds. This is a two Trip Fault.
  • I think your number is incorrect it should be p049db
    [TABLE="align: center"]
    [h=3]Possible Causes[/h]
    CRANKCASE PRESSURE SENSOR
    POWERTRAIN CONTROL MODULE (PCM)
    [/TABLE]
.[TABLE="align: center"]
[/TABLE]
Ok answer me this is the dealer gonna tell me it because i have a banks bullet and air filter set up on it??? Don't want to waste my time if i don't have to..??? C e l isn't on but won't clear with my cheap obd checker..
Aftermarket air kits and boxes/programmers can trip codes.First step would be to contact banks.The dealer has no responsibility to deal with a banks product on your truck
Dealer did pcm flash under warranty,and read me the riot act on after market parts!!! So far ok and seems to run better…. Per TSB#18-018-16...
