Well its been a few weeks later, and the truck was driving fine with only the faintest hint of unlocking(just a few times over the last few days) So, I figure I should swap the spare TPS back on to see if it helps. It worked fine for a while, but while driving home, the truck started acting just as I described in my last post. I swapped back to the other TPS- same symptoms. I tried clocking it, disassembling and cleaning, etc. Same symptoms... So I swapped in a perfectly good TPS from my '96, which is crippled in the shop with a busted u-joint at the moment... to be put back together tonight. :argh: The same problem of the trans. unlocking, then slipping into 3rd, continues. Now its also flashing on the trans. temp warning lamp for a few seconds as it shifts into third.
What could I have done in the removal of the TPS that would cause this to come back(with a vengeance)?
I'm about to go try a few things to see if there is just a coincidence of the TPS swap/unlocking/shifting problem.
1. Remove wires from loom(electrical noise? Still searching on that one but haven't found much info yet.
2. Unplug TSS and see if it stays locked correctly. If not, plug it back in...
3. Go to radioshack and get a 1K ohm resistor and put in the TTS plug.
4. Test voltage at the TPS. Would do this first but my voltmeter is in the '96 20 miles from me. I'd like to eliminate a few other things before I have to drive it that far in the condition its in. Is a digital voltmeter adequate for showing a smooth progression of the voltage(as in, not jumping around erratically)?
5. Permanently remove the TPS and install rheostat in cab.
Oo.
Am I on the right track with all this? About to go start testing, wish me luck.
