Lately I've had trouble building boost. With all boxes out I sometimes have trouble hitting 25psi. With the Juice in and on level 0 I experience the same thing. Sometimes when I crank the Juice to 3, I struggle to hit 30. I keep saying "sometimes" because every now and then when everything is working properly, I can hit 38psi with the Juice set to "0". There doesn't seem to be any rhyme or reason to it.
The EGT will climb easily to 1300+ relatively quickly. If I can ever get the boost to max out, the EGT will drop to a safe level and stay there until I back out of it. Usually I end up backing off long before the boost gets up high enough because it's getting too hot--1400*.
The Juice seems to be working as I can tell an obvious SOTP difference in take-off and hill climbing ability with a load. However, I have virtually stock smoke levels regardless of what level the Juice is on. The lack of smoke leads me to rule out a dying turbo.
I not laying this on the Juice because the truck still won't build boost to stock levels with stock fueling. It's just a lot more noticeable if I use the Juice to dump fuel in. EZ is out until I can get this figured out.
Do I maybe have a goofy MAP sensor? No codes. Fuel Pressure gauge tells me everything is fine with the LP and fuel filter.
If I didn't have gauges I wouldn't know anything to be wrong. Truck sounds/acts normal otherwise
