1992 Cummins starts fine first time -- after driving a half hour or so, won't start -- cranks strong, cracking injectors no help, pumping prime lever of fuel pump no help. Let it sit a few hours or overnight and starts fine. What the heck?
Never off or updated -- 225,000 milesWhen was the last time you have the injection pump off and update?
Shut-down deliberate -- run fine and strong until turned offFrom the Factory Service manual:
"Restricting the fuel drain manifold raises the case pressure of the injection pump which can prevent injection.
If the engine will restart after a waiting period following an unexplained shut down, look for a restriction of the manifold drain line.
Note: Restriction can cause the fuel temperature to rise reducing power from the engine"
