Today on the way home after about 130 miles of driving and thankfully only about 2 miles from home, my truck lost its mind. I had just topped a hill and it pulled fine, nothing out of normal and as I coasted to a stop sign, I noticed all the sudden it was making much more exhaust noise, surging and when I checked my Edge insite, I had zero boost. I left the stop sign and it never made boost until I gave it a little extra and it made a whooping 1 lb and returned to zero. It was not smoking and other than losing power and being noisy, it let us get home and didn't strand us. No codes present when I ran codes. I checked all the pressure boots and didnt feel a hole or find anything loose. My son said he noticed it smoked a bit each time I started it, just normal black smoke and it didnt continue...just a puff when it fired up. There is no sound of spooling unless I give it a quick blip on the throttle and then its barely noticeable. Turbo was replaced about a month ago since vanes were hanging up, so its same as new.
I thought I smoked the turbo but from what I am gathering, I should be seeing it really smoking heavily, esp on my drive home and that is not the case, its just abnormally loud and semi gutless. I checked rail pressure and I have 4.8 at idle, 5.2 at 1000 and 7.4 at 1600 rpm.
Truck is an 08 6.7 fully deleted, with efilive. I removed my edge and cp5 switch to make sure for some reason one of those hadn't gone nuts...no change.
Thanks for any help you can provide!
