Today I moved up to Firestone SteelTex 265/75's Load range "E", had a set of 245's to start with. It's made a little difference in my speedo/odo readings. By the stopwatch, the speedo is almost exactly perfect at 70 mph. Problem is now, the odometer now only registers 9. 5 miles for 10 run, on known good mile markers. On 97's it's easy to swap out the speedo gear in the transmission. I'm think about dropping a tooth on the gear, to speed up both the speedo and the odometer. That might get the odometer closer first, then by driving with the instrument bezel out, pull the speedo needle off, & reposition it to the correct speed I'm travelling at the moment by the stopwatch. (with curise on) I remember a post about someone using this method, but can't find it. It makes me nervous to think about pulling the needle off & sticking it back on. Anybody tried it?
