2nd Gen Non-Engine/Transmission Odometer dead.
Engine/Transmission (1998.5 - 2002) Oil Analysis
Engine/Transmission (1998.5 - 2002) Help needed - power steering leak
The odometer on my 2000 truck shows 0 and the trip odometer will show milage until I turn the truck off and at restart will go back to 0. At start up or restart the odometer will switch back to the odometer setting even if you had it set on trip function before it was shut off.
No codes come up on the 3 key on/off and disconnecting the batteries overnight did not help. Any one else ever have this problem?
Could it be the display/ gauge cluster or should I be looking at the PCM. All my other gauges work properly and truck runs great. What to do?
