OE Trans Cooler Flow Direction
Looking for OEM front bumper............
wont start
On my 91. 5... which direction does the fluid flow through the ATF cooler up on the radiator support? Or which line is the inlet side? Thanks!!
Flow is to the heat exchanger, then to the radiator mounted cooler, then back into the trans. The fluid comes out of the line w/the sensor mounted.
