Hello,
Can fuel pressure be adjusted on the 2nd gen OEM fuel lift pump? I’ve heard that the 1st gen CTD’s are adjustable.
I ask because over many months I have noticed a slight loss in power. I should probably replace the fuel filter first. Last did it 10K miles ago.
What I really need to do is install the FP, boost, and EGT gauges. For now, I’ll have to check pressure with a manual gauge on the post-filter port (before and after filter change and under load) to see what it’s telling me.
As far as the lift pump, should it replaced as a preventive measure (and if so, when), or do most people just wait until they fail before replacing?
If I find that I have low fuel pressure, are the only possible causes a clogged filter, pump that is about to fail, etc? Or are there other possibilities?
Thanks for your comments/suggestions.
Matthew
Matthew
