bcbender
Has anyone with the OEM powered steps had an issue with them not deploying? I recently noticed that my left step (PS) was hanging up when my son went with me to the quarry. I know they have a feature to return them if they detect and obstacle, (had this happen on my lift once and once off road when they were close to the ground). I assume its function is current based and so I don't know at this point if the step has too much mechanical resistance causing the motor to return it, or if the motor or gear box is the issue. A few cycles and it'll go down, but then sometimes it tries to return and gets stuck deployed. The display simply states "Power Steps Not Available" when this happens. I cycled them a few times last week and now it seems fine, but since its the left side is does not get used every time I drive like the right. Don't want to take it in yet as I'd be on my Maxcare now and have to throw down some coin.
Cheers!
Brian
Cheers!
Brian
