Off topic But.....
Fuel Pin
Lets Talk Batteries
Hey all,
I know this is a bit off topic but it seems as tho there are some real knowledgeable people here so I thought I'd post anyways.....
I recently bought a Case 680E Backhoe / loader that came w/ the three stick & foot swing controls for the back hoe. I am trying to locate a wobble stick (2 stick) control tower for the backhoe (I am use to the 2 stick controls). Any ideas on where I can locate one? I think the Case dealer said the controls from a 680 G may also work on my machine.
Thanks in advance for any and all help.
Andrew
Andrew,
I don't know if you already have, but if you posted this to the "Other" forum, and titled it Case Loader Question, or something like that, you'd get the input from everyone.
As to me, I can't help you.
YT Mag.com has a dozer/construction equipment discussion forum,and links to other related sites. Might give them a try.
Go to your Case dealer and have them look up a set of 2 stick controls, and have them check DPNI. It is a warehouse for out of date and obsolete parts. I work for a Case dealer and we swap controls all the time on 580L's and M's. You will probably have to change the spring on the valve swing spool, as they are different strengths from foot to hand.
The other option is to check equipment junkyards, as they may have what you need. I don't know if G parts will work, as I don't usually work on the older stuff ( and the guy that's been there 33 years retired on 1-06 ).
Good luck!
Hey Andrew, you should send a PM to one of our guys on here... his nickname is Case500D.
He is pretty up on this sort of thing and I'll be he can help ya pretty quick...
pb... .
